Pictures Needed of Throttle Lever for Universal Diesel Newport 28 MK II
Mar 24, 2016
5
Newport 28 MK II Halifax
I need someone to take a picture of their throttle lever for their universal Diesel from a Newport 28 MK II. I need to have one built since I can't seem to buy one from the factory.
When I bought my boat it was broken and whoever fixed it must have been a relative of Rube Goldberg. (I now have two opposing levers to do the work of one) It makes for a jerky throttle when docking.
Any help would be greatly appreciated!
209
Capital Yacths Newport MKIII 30 Punta Gorda, Fl
I have a Newport 30 with a Universal M18. I am not sure if it is the same as yours or not but here are 2 pictures where you can see my engine.
Mar 24, 2016
5
That looks like the engine, I can see part of the throttle lever in the picture. Is there any way you can take a close picture from the side and the top?
Also, do any of you have an actual filter in that snail shaped air box?
I joined the Facebook group too.
Thanks everyone in advance for your help!
Mar 24, 2016
5
I was looking at my engine with confusion today. I'm going to double check the model, because I am missing the circled parts in the attached picture. And I think my throttle cable has a twist in it like a picture from a Catalina I found online. Anyone able to offer any insight? I'll try to take some pictures of my engine tomorrow.
4
Newport 28 Mkii ST. PETERSBURG, FL
You've been super about posting pics. Do you mind posting one with the port side of the engine? Trying to connect fuel pump etc.
Feb 26, 2017
4
Need to know which lines coming out of the boat connect to the pump. I think I see what I'm looking for. Mine is electric too.
Jun 5, 2014
209
Look at the top picture. The line you can barely see at the top of the white Racor fuel filter is coming from the gas tank. the fuel line on the far side of the Racor filter goes to the electric fuel pump bottom hose on mine (on the second pic you can see the word IN) The top fuel line coming off the fuel pump goes to the engine.
Jun 5, 2014
209
In this picture the Fuel line you see at the bottom right is coming from the top of my electric pump. You can see a secondary fuel filter that screws on like an oil filter under the fitting where this line connects.
Jun 5, 2014
209
I just noticed you are in St. Pete. We south of you in Punta Gorda, Fl
