E
emalsyd
will a PHII with a household size bowl fit in a '78 cat 30? also, can the holding tank vent and the vented loop vent be installing high in the hull right below the deck or should it be installed in the side of the bulkhead.if the holding tank is installed in the bow could i vent the tank through the port or starbord running light holes which are located high on the hull right below the deck at the bow of the boat? i am planning to relocate the lights. rather than make a new hole in the boat i was wondering if these would be high enough to act as the vents. after reading peggy's book i was thinking i could run 2-1" vents for the holding tank. one to each light hole?
