Pex
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
i think if you are talking about your fresh water system they should be ok fine.....
regards
woody
Rick D
Jun 14, 2008
7,186
At least one generation of Hunters had it. Mine for one. I'm happy with it. My former one had it too. That's 24 years experience with it on boats.
njsail
Feb 18, 2010
216
Bavaria Ocean 40 CC Forked River
I actually prefer pex over the re-enforced nylon hose many boats have for water. The pex is harder and doesn't seem to absorb the smell some water hoses get when they sit. I wouldn't hesitate to install pex on the fresh water side of a boat water system. I've worked on plumbing houses with pex and it is easy to work with and goes in relatively quick. Just make sure to size the diameter properly so you get a good flow.
KD3PC
1,069
boatless rainbow Callao, VA
it sure beats the "gray" RV crap that was originally in my 1991 42'. Not a single issue since it was installed and the water tastes great.
Go with a standard size, or buy a few spare connectors/fittings when you buy it. I have a few spares, but no need yet and it has been almost 5 years.
I did the red and blue, so it is easy to see what is what.
All the best
Feb 6, 1998
11,709
Red/ blue is nice. I have a good source locally for 3/8" PEX and fittings and it is MUCH easier to work with than 1/2" PEX. Either way STRAIGHT lengths are far easier to work with than coils. I prefer the Watts/SeaTech plastic fittings as they don't corrode and look like crap three weeks after you completed the job.
Building this manifold too literally two or three minutes...
You don't need to pay "marine" prices. Watts owns Seatech and sells the identical fittings under the Watts brand... I pay about 35% less through my local plumbing wholesaler...
Please be very careful that you are buying either all metric or all US pipe size. Early on they forced metric PEX & fittings into the marine market so they could charge us boat loads of money for "proprietary" marine PEX and fittings. A lot of the metric PEX is still out there and it will not mix with US sized PEX.
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I believe they sell the elbows, tees and pipe at Lowes.
