Barrier Coats
IMHO, you don't want to confuse bottom paint, even modified epoxy types, with barrier coats. They are different and each has a unique function. (BTW, Petit Trinidad is a great multi-season bottom paint). I also think that barrier coating has been hyped by the industry to a lot of people who don't need them. The first question you need to ask is what is your need? If you have a number of small gel coat blisters, it's easier to fix them individually. Even a few deep blisters in the laminate are easy to fix. See this month's "Good Old Boat." But if your boat has "the pox" everywhere,you are going to need to strip the entire gelcoat, dry out the hull for a loooooooooong time, and then rebuild it and barrier coat that. Very few boats really need this radical treatment. I hope your's isn't one of them.Another thing to keep in mind is that if your hull is going to blister, it is going to blister whether you have a barrier coat on it or not. The migration of moisture to the surface can be slowed, but not prevented, and it happens inside and outside your boat, and above the water line too. Barrier coats will not help you there.
