Doug Washburn
1. i spent this weekend removing both sanitation hoses plus the vent hose. the evacuation hose is back in with the rest to go in next week. my question concerns the evac hose. it seems to me you would not want any section of that hose to be lower that the evac fitting in the tank. however, the way the hunter is designed, it appears to to do so as it makes its way to the deck fitting. am i just paranoid or should i do whatever it takes to keep the entire run higher than the tank fitting?2. i am using the sealand odorsafe hose for the main hoses. does it make a difference what hose i use for the vent?
