Permanently removing Thru Hulls
Stephen Ord
On my Hunter 30 I still have a thru hull fitting for the direct discharge of waste. It is no longer functional (connected) and I wish to remove it and patch the hull. Any suggestions or ideas on patching the 2 inch hole in my hull?
Peggie Hall/Head Mistress
Why not just plug it instead?
Chances are, you will not be the last owner of your boat...the odds are at least 50-50 that a future owner may put it in different waters where that thru-hull can be used. There's a very good chance that you can use it in the future, when the Saxton Bill is finally passed, allowing the use of a treatment device instead of a holding tank, even in "no discharge" waters. I'd leave well enough alone if it were my boat.
Jack
Patching
I also have the same issue since I will never be able to discharge overboard. I do not like having the gate valve there and have though about removing the gate valve and then capping the thru hull itself with a bronze cap. Sounds good but I also want to leave my boat in the water over the winter and wonder if there would be enough threads to hold the cap in case of a freeze problem. Curious about other peoples thoughts.
The best solution, Jack...
Replace the gate valve with a proper ball valve seacock. In fact, you should replace ALL the gate valves. That'll require a haul-out...but meanwhile, you can protect the boat from any failure due to freezing by attaching a piece of hose to the thru-hull that extends at least a foot above the boat's waterline...then put a plug in the end of the hose...or not. A plugged hose just looks better to any legal beagles in an inspection than one that isn't, but it's the hose itself that provides the protection.
Bill Ebling
Save the thru-hull - Cap it
I removed the direct discharge portion of my system when I replaced my sanitation hoses with odor free SeaLand hoses. Since I can't legally pump overboard in my Chesapeake cruising grounds, removing the hoses, vented loop, discharge pump and Y valve for the direct discharge portion of my system further helped me get rid of odor/permeation problems from waste laying in the unused components of the system. I removed the original (dangerous...frozen) gate valve for the direct discharge thru-hull and capped the thru-hull with bronze cap (Available from West Marine). In the future if I (or a future owner) wants to take the boat off shore, the thru-hull is still there to allow a rebuild for overboard dumping without hull modification. Yesterdays Dream 1985 H31 Hull # 31395
Peter Albright
Gate Valve easy to remove
On my 1977 H30, the gate valves were not frozen. When I attempted to close them to replace the hoses, the top of the valve popped right off. There was so much leaching of the non-marine bronze, that there was nothing left. To remove the gate valve from the thru hull, all you need to do is tap it with a hammer.
Bob Howie
Don't remove it
I'd suggest keeping the thru-hull in place and just capping it off as has already been recommended. One day you might add a system requiring a thru-hull and you'd already have one in place. Removing one entirely is something I don't hear about much around the shipyards hear and I would imagine so doing would require quite a bit of work to ensure it was properly sealed and would never leak or become a maintenance item; more so that just filling a hole with epoxy and painting over it.
