PERKINS PRIMA 50 needs fuel booster pump???
Jul 13, 2009
84
Parker Skipjack 37 Clearwater
To start my prima 50 it takes about 10-15 seconds of grinding starter. pretty sure its fuel pressure leaking down. On previous similar boats i have installed a inline 12 volt low pressure booster pump. This also helped to fill and prime filter bodies when changing filters. Any comments and or suggestions as to value/need and pump model? Thanks. George
Jan 4, 2006
7,439
Can't offer any help with the starting problem without being there.
As far as a 12V lift pump, I went with a CUBE and it works like a charm. Be sure to get the one which passes (not pumps) fuel without power. There is no difference in engine RPM with the pump in either the ON or OFF position.
See here for a few more details:
