BOB
I have a 95 Beneteau 351 with the Perkins Diesel (Ibelieve the model # is M30). It overheats a cruising speed...past 270 degrees F, 100 C. It eventually cools down when the engine is at low RPM. I bought the repair manual but it does not specify what temperature is normal, although I would think somewhere around 220F would be normal.I changed the impeller, made sure there was no blockage I could find and decided to replace the thermostat. No problem until I find out that the therostate is behind the water pump and that the whole pump assembly has to come out. I pulled off all the necessary parts and got down to the pump removal step but the pump wouldn't budge. Decided not to force it off and put everything back together.Questions:Has anyone had a similar experience with this engine? What's your operating temp?Is there another source of the problem you encountered?If you removed the water pump to change the thermostat, how did you do it and what tools did you use?If you did change the thermostate, did it solve the problem?Many thanks!
