Purging Radiator
Bill,Certainly not an expert on Perkins but all the engines seem generally the same. Here goes. Think your larger problem is on the anti-freeze side (af) but check the freshwater (fw) side first. Check the oil and look for a milky color. Thats what antifreeze looks like in oil. If not there continue.Last time you ran the engine did you get water out your engine exhaust? If you did then assume that side is ok for now. If not, open the waterstrainer and ensure there is good flow coming into the strainer through the engine thru hole valve. Check the various sections of hose into the "radiator", out of the radiator, into the mixer elbow. Thats about as far as you can check. Just disconnect each section in turn and start it up for about 30 secs. You should have flow almost immediately. My bet is this is not the problem. If it is check/recheck impeller, pump, belt, hoses.On the af side. I would get a radiator tester from a service station and check that the radiator/system will hold pressure. If it does then the af fluid should be staying in the system. Start the engine up with a full radiator and cap removed. Wait for the internal thermostat to open and you should see the af level suddenly drop. Fill it back up immediately and keep doing this until the engine won't take any more. Sometimes it helps to lift the hoses to help remove trapped air but be careful you don't force hot af out of the open radiator. Until you get all the air out of the system the engine will not have sufficient af to cool properly. You have to ensure the water heater, all hoses, engine internal chambers, radiator are all full. Also ensure there is af in expansion tank and that all hoses are in good shape. Sounds like someone drained the system and never refilled. Other problems might be engine head gasket, internal af pump, thermostat, crack in radiator. All this and more should be in your engine handbook. Check online and get one before you try anything drastic.Good luck,Less/v Mutual Fun
