Deep Keel VS Shoal Draft
You should typically expect a deep draft fin keel to point at least 5-7 degrees higher and sail marginally faster than the shoal draft version. The deeper wing shape is more efficient. The shoal draft is more tender, even with 500 more pounds of weight.You should anticipate that if the leading edges of each keel are located in the same point on the hull, the shoal draft keel is longer; has a center of lateral resistance further aft and higher up; and therefore will promote weather helm sooner as the wind picks up. Because of this, you might set up a shoal draft boat with a smaller Genoa and be slower in light airs as well.If you want to race the boat, look up the PHRF numbers for both and expect the deep keel to be at least 6 to 10 seconds a mile faster.Of course if you always sail in shallower waters, the 12- 18" typical depth difference may be more meaningfull to you as well. If the shoal draft is a 'wing' keel, which it may be on newer boats, I feel there is a distinct disadvantage if you ever run aground - it's a great anchor on a falling tide.I first owned a 3' deep shoal draft Hunter 25 and now own a 5'-2" deep draft Hunter 28.5 which is set up for performance, so that's my particular bias. I'm sure you will see other opinions and valid points here as well
