Perf Rate for 28.5
Rick Bojahra
We are having a problem establishing a perf rating for my 28.5. Can anyone provide some input on the ratings provided on your boats (28.5 only please) and the location of these boats. Also fresh water would be preferred. Thanks Rick Bojahra
C
Cliff Ruckstuhl
Lake Erie
We are a 174 for the Spinnaker class and a 184 for JAM or Jib and Main. We are also a deep keel boat. Shoal draft gets a different number CLiff " Red Dog"
S. Sauer
PHRF on Chesapeake Bay
We've been sailing Celebration II, a deep keel 28.5 on the Chesapeake Bay with a PHRF rating of 174 since 1986, which includes a maximum 155% Genoa, no roller furling and a folding prop. She has always been able to sail to that rating (non-spinnaker) and performs particularly well in light air, most of which I attribute to a Baltoplate wet sanded bottom finish, the Martec folding prop and a Headfoil system.
Steve
2003 PHRF book...
There are quite a few 28.5's in the PHRF book, broken into two groups...standard keel and shoal draft. The std keel rates from a low of 121 to a high of 201. Most are about 183-186. Lake Ontario has a boat at 171, and Detriot has one at 174. The shoal draft boats run form 180-195, most being 186-189. LAke Erie has one at 186, and Detriot has one at 183. What you really need to do is apply for a rating from your local PHRF board, and go in with LOTS of data to support your boat. It is a local decision based upon how your boat can performs in local conditions in 8 knots of wind. Comparisons to other boats by length, weight, sails, hull, keel, and many other conditions. The more info you have, the better your chance of an acccurate rating. Of course, if it is just for local club racing, then the club can give you a rating. Good luck, Steve
