Ooops
Well Peggy, either we are having two different discussions, or I'm a bit addled. The latter is most likely. But, perhaps I may be excused in that I have been struggling to boil the complexities of IRS Section 1031 Like Kind, Tax Deferred Exchanges into a one hour presentation for Realtors (which I think came of pretty well this afternoon).I thought we were talking about teeing in a supply line to the sink drain in order to make it easy to do a final fresh flush(alliteration is so delightfully tacky). In my hidebound mental state, I assumed that since we were adding a tee, we had two throughulls to deal with and I wasn't even contemplating a single through hull setup ('cause two's the way my boats have been and are rigged and I've never actually used one on anyone else's boat yet...duh on me). Otherwise, the head inlet is used for normal operations and the wye valve is only used for a little fresh water PM when leaving the boat. As the lowest ranking sailor aboard our vessels, that task almost invariably falls to me and most of the time I can get it right after a little fumbling around. BTW, we just bought Commitment in May and I haven't even gotten around to actually adding the tee and wye yet (way down on the list still). For now, I simply use the shower to freshen the bowl and outlet hose and we use the head frequently enough to keep the inlet water hose from getting too rank. There is an added benefit in that we move more water through the tanks more often, minimizing stagnationWith a single through hull you are, as always, correct...a wye valve would be superfluous. Anyway, you can certainly see why I wouldn't be culling MENSA members for company. Not very good for a fragile ego.Best regards,Chris
