Tim
Peggy,We just bought a new (previously sailed) boat which needs the fresh water system cleaned. I went to your article, Fresh Water Maintenance, in the archives and am confused about the amount of bleach to use.You say to use a solution of 2 oz. bleach to 1 gal. water, and use 1 gal of this solution for each 5 gallons of water capacity. If I do this, I'll have 4 oz. of bleach in 12 gallons of water, for example.Later in the article, you say that anything less than 8 oz. in 10 gallons of water won't do anything. I don't get it! How is the "cleaning solution" supposed to work with 4 oz. in 12 gallons if 8 oz. in 10 won't do anything?Did I read this wrong, is it 2 oz. for every gallon capacity?Better yet, I have 55 gallons of capacity, if I fill it up, how much total bleach should I pour in?Thanks,Tim
