Peggy - odor question ??
Pete
Peggy, Just interested to hear what you have to say about a product called "Nature's Miracle". Have you heard of it and what do you think of it ?? It is actually a "Stain and Odor Remover" sold in pet stores. It works great in a household environment (tested thanks to new puppy) but was wondering what you have to say about it with regards to a marine environment and in particular for using it after cleaning a bilge as a preventative rather then a cleaner or possibly for getting into those impossible spots to reach ?? Thanks for your input ! Pete
Dec 2, 1997
9,011
- - LIttle Rock
It's a microbial product, similar to Raritan K.O.
It can't hurt anything, so feel free to use it. However, it'll prob'ly require a LOT more of it to work half as well for a much shorter time in a bilge as products that cost more at the cash register, but are so effective that you need so much less that they actually cost you half as much in the long run.
W
Wally
Nature's Miracle
This product saved our bacon after a nasty little holding tank leak on our Legend 35. The effluent had leaked down into the foam that the tank was mounted in and it proved impossible to scrub clean by hand. Upon recommendation from a friend, we bought the stuff and poured a bottle, (after fixing the leak first!), around the area where the leak had occurred. The reasoning was that it would take the same path as the "bad stuff". Took a couple of applications, but worked like a champ!!!! I have nothing but good things to say about this product. Did the job for us.
