H
Harry
I don't know what happened, but only 1/2 of my original post was posted, so here goes again.The bowl is below water level when heeling and it's filling thru the drain thru-hull. The hose is a 200PSI in a straight run(about 24")from the bottom of the basin to the thru-hull. There may be enough room to replace & reconfigure the hose to make it similar to a house-hold sink drain ("S" shapped). Would that solve the problem? Should I stay with 200PSI (seems really heavy duty and hard to form)?Should I include a vented loop? In that tight of space, would such a small "S" do what I want it to?Of course, I could just keep it closed while under-way, but I'd rather not. As usual,thank you for your thoughts.
