Peggie,
Earlier this year you out lined how to completely re-install the head in my H27. (PO had removed it and put in a porta potti) You suggested using fresh water for flushing vs seawater, you also outlined how to plumb the head sink drain to fill the flush water tank.
I installed a manual pump head, 26 gallon holding tank, 3 gallon flush water tank (plumbed to diverter valve in sink drain) a vented loop, tank vent and filter, thru deck pump out. I also have removed the thru hull discharge completely. The installation has been inspected by a RI head inspector and I have a Green certification!
Thanks for your advice and effort it is truly appreaciated!
Brian Savulis
Brian Savulis
