AND if it's windy or warm
I agree with the other posts, in addition, use blue masking tape, the 2 inch stuff that sells for $9 a roll, and tape all the joints in the paper, and the waterline. when you do this the remover stays wet, and it does one heck of a good job, messy, but good. a cheap throw away trash can for the paper and residu is also a good idea.Begin your peel where you started, wipe off as much as you can, we found that when it dries on the hull it needs to be sanded off, or another peelaway treatment. On our job we removed 5 layers of paint. Good Luck!
