Peel away
K
Ken Durbin
I have my boat hanging from I beams,and have removed the keel.Soon the keel refinishing will be done and I will be ready to start on the bottom.I am planing on using Peel Away to remove the old paint.Has anyone had any experince using this product?Will there be more sanding? Thanks Ken
SRFRR
PEEL AWAY IS AWSOME! I USED IT AND TOOK OFF ABOUT FIVE OLD LAYERS OF PAINT AT ONE TIME. THEN I USED IT AGAIN. I STILL HAD TO USE A DISK SANDER, BUT ONLY A LITTLE BIT. I HAD EVERY LAST BIT OF PAINT OFF THE HULL. PUT A BARRIER COAT ON BEFORE YOU BOTTOM PAINT. IT WILL KEEP THE BOAT WATERPROOF FOR LIFE. I USE AN ABLATIVE PAINT THAT I LOVE ALSO.
