Merriman Notes
Attached is a note from some years back.. since the Constance Machine folks are close to Everett, there may be some connection, but it is worth a call anyway. I bought my replacement about 12 years back from those guys.. The place in Canada may be worth a call as well.. Good luck .. A good machine shop can duplicate it but it will be expensive..
" A reply to MERRIMAN-Yacht Specialties Pedestal Parts
I had the same problem on my Legend 37 September of 2007. The PO made a repair on the shifter tab with epoxy and glass, but it didn't stand the test of time. I purchased a new cast aluminum head that was machined perfectly. I picked it up from Constance Machine in Everett, WA. Phone number is 425-347-8920. It took some time to get it because he was waiting for a few more orders to come in so he could make the minimum pour.
The control head will come polished with bushings for the throttle and shifter. It is bare, so you will need to paint. I dropped mine off at a local shop for a quick powder coat. It is solid and a perfect match.
Good luck!
Brice
s/v Maji Tembo
There are no more parts available. HMP (Holland Marine Products) in Canada is willing to cast new shifter plates for re-sale if a customer is willing to send in an old one as a template. I would have sent mine up there but it broke mid season.
I repaired it with Devcon Plastic Welder, 1" fiberglass tape, Dremel and sand paper. It's still working fine. I painted the finished side with Krylon Fusion but left he underside raw in case it breaks again.
If you are hauling out for the winter call HMP and see if they are still interested in casting a replacement."
