Pedestal
R. Shay
I have a 1985 Hunter 34, with I believe a Edson Pedestal. My chain must have lost or broke a link, and it came off the gear under the compass, and fell downl leaving me with no steering. I believe that I have to remove the pedestad to retrieve it. The pedestal looks like it is held in place with four large phillip-head screws, screwed into the cockpit floor/sole. Assuming I can get these screws out with a large screwdriver, what else is required to get my chain and get it hooked up again. In advance, thank you.
Hunter 34 Seabeck WA
Stop! Easy fix.
Crawl into the aft berth. Remove the cover on the ceiling. Then remove the four nuts that are on the bottom of those Phillips head bolts. Drop the sheave. The whole world opens up. Nothing to it. And if your pedestal is original it was made by Yacht Specialties. Have fun! Edit; If you're a newbe you need to know this. The wires coming up from the sheaves to the chain MUST cross inside the pedestal or the boat will steer backwards!
Dec 2, 1999
15,184
I believe you probably have a Merriman Y/S
You probably have a Y/S Merriman pedestal. If you can find a manual you will have better luck in making repairs. Motion Industries usually has chain and links that you can use to repair a chain.
Jun 21, 2007
2,117
If It Is a Yacht Specialities Unit -- I took Mine Apart
Dear Mr. Shay If it is a Yacht Specialities pedestal, below is a a cut-and-paste from a posting that I submitted a few months ago. Maybe some nuggets of info you could use. Per Mr. Ficarra's post, he is correct that the wires do cross inside the pedestal as I describe below. Also note my comment that one of the sheaves underneath the pedestal that route the wire back to the steering quadrant is a bit forward of the other. You would not notice this unless you know about it. Make sure that the wires are routed to the correct sheave so when they cross, they don't rub against each other. --------- As already posted by Grizz, although Yacht Specialities is defunct, Edson is a source of info. On the web page www.edsonmarine.com/support/techsupport.php you can find a pdf file entitled, ".... Planning Installation and Maintenance Guide." Its for their newer products, but it looks like many of the principles are similar to the Yacht Specialties system. Hopefully your cable just became loose over time and finally it slipped out the quadrant cable channels or off the sheaves that angle the cable from the pedestal to the quadrant. But if you do need to take your system apart here's some info about my experience: I did find it useful take close-up photos and make notes of each section before disassembly so that I would have better chance of later remembering how to put it back together. I can’t give you step-by-step guidelines, since I didn’t retain my notes or pictures. But how it fit back together is rather logical. Took a few hours to remove the system and reassembly took me a full afternoon. You probably will be dealing only the the cable/chain/sprocket system, but if the whole pedestal needs be removed, throttle and transmission cables need to be removed/re-attached from the engine side as well. (About a loose cable, before my cockpit sole repair, my cable was somewhat looser than I would have expected as normal ... "not to loose, not too tight". Perhaps this was because as the wood core rotted/delaminated between the upper and lower fiber-glass skin, the pedestal was depressed downward from normal which loosened the tension? My tip-off about the core damage was that the top of the pedestal/wheel assembly would move from side an inch or two when pushed ... it didn't feel solid.) One thing that I did do wrong on my first refitting of the steering cable is that I hadn't noticed that the cable crosses over itself inside the pedestal. That is: If you are standing to the aft of the pedestal looking forward, the chain/cable that drops from the starboard side of wheel chain sprocket crosses over to port sheave that angles the vertical drop of cable back to the quadrant. The other side crosses from port to the starboard sheave. Also although its not readily noticeable, one of sheaves is a bit forward of the other. This is so the cable sides don’t rub against each other as they cross inside the pedestal. This routing inside my boat was hard to see on my boat, but I probably would have missed the cross-over even if it was right in front of me. So best as you can, try to observe and record the routing from the chain sprocket to the sheaves and also the routing quadrant/attach points before you take the steering chain/cable off. If the cable doesn’t cross over itself inside the pedestal, the steering works, but turn the wheel to port and the boat goes right and vice-versa. While I was at it, another item that caught my attention was the molded plastic housing into which the gear shift and throttle handles are set. This is the piece that Ian McGain photographed and was unable to remove the four screws from. I had better luck as my screws came out. While I was researching Yacht Specialties pedestals in preparation for my disassembly project, I read somewhere (probably deep in this forum’s archives) that people have had problems with the plastic housing breaking inside where the shift and throttle lever shafts and cables are anchored to the housing. The accounts cite that if a cable anchor or throttle handle breaks free inside, one might not be able to (say) shift out of forward into reverse. Or the throttle might get stuck at full (or idle). Or the broken-loose part could jam in the steering chain. Any of which would be a heart stopper for sure if the failure occurred (say) after committing to the final turn into a berth. When I had my part removed from the pedestal, I did discover the beginnings of a stress crack near one of the cable anchor points. The web references said that this pedestal part is no longer available and a casting shop would have to custom-make a replacement. I decided instead to reinforce all the potentially suspect areas by encasing/epoxying them with custom bent u-channels I made from stainless steel sheet metal. Then I poured in lots of West Systems epoxy all around to ensure that nothing could possibly ever break apart. Back to your harrowing few moments after the steering failed, your narative rereinforced the wisdom of my decision after reinstalling the pedestal and steering system, to also check out that emergency tiller would function. But when I went to fit it to the rudder post, I found that there was absolutely no way to attach it ... zip, nada. On the boat, there was still the log book of a cruise to Mexico made in 1991. Off the coast of Ensinada, the steering failed and the owner had to be towed in. Repairs took a couple of weeks. (But probably the owner wasn't in a hurry anyway and Tequilla was cheap back then.) I expect that the Mexican yard never put in the fitting for the emergency tiller. Why the owner and subsequent owners never corrected is beyond be. I made a fix and the emergency tiller slips on to the post fine while the boat isn't moving. But your experience has prompted me to practice fitting the emergency tiller the next time I go out. I might find its not so easy when the rudder post is rotating back and forth due to waves and rolling motion pushing the rudder around. Better to discover now that maybe a modification should be made now than making discovery during a real emergency. regards, rardi
