Pedestal table night light Beneteau 343 2007
Oct 14, 2020
28
Beneteau 343 Burnt Store
I have my Beneteau 343.. and the Pedestal table night light doesn't work. Any suggestions where to get a replacement. I know sait air corrodes this stuff.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
As always, a picture would help. Try the beneteau parts site, or the SBO store.
You may not need to change out the entire fixture just the bulb if the fixture is not too corroded.
Aug 27, 2014
91
Beneteau 373 San Diego
Most likely yours is like mine. Comes from Barnegat Light Marine Products. See this: Cockpit Light – White | Barnegat Light Marine Products
It may be that your bulb has burned out. I replaced mine with their LED model # QL-CP-WLED. Takes up less power at anchor and no bulb to replace. Also the screw head on either side of the light may be a machine bolt, not a screw so you may need to take the back off of the instrument housing to remove the light to get at the machine bolt's nut.
Jun 21, 2004
2,913
Beneteau 343 Slidell, LA
If you are referring to the light on the forward side of the steering pedestal / helm station, it is a Barnegat light.
Check here on the SBO store for a replacement bulb. As "Helm" mentioned, you can upgrade to LED; however, you will have to replace the entire light to do so. Again, the light assembly is available on SBO store. I recently purchased the red/white LED version; you will also have to purchase a 3 way toggle switch for that light.
Apr 6, 2019
3
Beneteau 423 Portland, OR
Double check to see if the connector has not fallen off on the back side of the light in the interior of the pedestal. After buying a new bulb I was frustrated to find that that bulb was not the problem. I eventually found that the wire had simply fallen of the connector to the light on the inside. Easy fix as soon I saw that.
