pedestal guard
Nov 28, 2013
1
hunter 27 carlyle il
I just purchased a 1981 hunter 27 and would like to had a pedestal guard. I Need to know the model of the pedestal and what is available. Thanks
Nov 21, 2008
23
Hunter 27 Cadle reek
If your boat is set up like mine, then it is an Edson and you can find the information on line. I found the installation instructions on there site and it has most of the information you need to determine your exact set-up and what other items can be used.
Jan 4, 2007
406
Hunter 30 Centerport
Your boat probably had a Meriman pedestal and they're no longer in business. Edson has pedestal guards than might work but you may have to to improvise
to get the support plate on the upper portion of the guard to fit the Merriman pedestal.
Good luck
May 24, 2004
7,174
CC 30 South Florida
I did just that on a1983 h27 quite a few years back and was able to use an Edson support plate. If I recall correctly the support plate was available in two different sizes. I remember I disassembled the upper part of the pedestal and traced a template showing the size and the location of the holes to be able to match to the correct Edson part. The plate came with the kit which included the tube and all the hardware. Check the Edson catalog. Sorry I cannot help more than this but it has been a while and don't recall specifics. I did install the tube with the square bend on top.
Mike 1
Sep 19, 2010
62
Hunter h27 Sandusky,Ohio
I just installed a guard on my '82 H27. I have the yacht specialty pedestal and I bought an Edson guard. I had figured I would have to modify it but in the end all the holes lined up on the upper plate and it took only took a couple hours to do the entire job. It was by far the best piece I have added to the boat!
Mike
Dec 2, 1999
15,184
Just something to consider. You can get either a narrow or wide plate for the guard. You probably want the narrow (about 9" vs 11"). You can have a shop bend the tubing so you can attach it to the pedestal rather than drilling hole in the cockpit sole.
If you decide to mount it into the sole be sure to caulk it properly (maybe butyl). Leaks from the guard are common and cost a lot to repair.
