G
Gerry Bogert
The boat is a 1985 H31 and I want to install a pedestal guard. The pedestal was manufactured by Merriman Yacht Specialties. I believe they are no longer in business. An Edson distributor recommended a kit from West Marine. I was told the bolt pattern would be the same but the diameter of the plate may be 1/8" larger than the assembly on the pedestal. The plate was too large, the bolt pattern was incorrect and it would not fit between the shift and throttle levers. Has anyone added a pedestal guard to this model? If so what equipment and where did you purchase it?? Anyone with pictures??Thanks,Gerry
