Yes, Honeyman
I read similar articles about the longevity of PBO. Both Navtec and West Marine are rating the longevity based on percent of working load. However according to Sailing World, "It seems that these life expectancies are driven more by the lack of historical data than science, because the fatigue resistance of PBO far exceeds that of steel."So it looks like these suppliers are opting for a conservative view much like boat builders of the 70's and 80's with their use of fiberglass. After years of experience they found that cutting the fiberglass construction in half would still produce an amazingly sound vessel. Today hulls are built at less than half the thickness of the ones from that era.None the less the cost of upgrade is a factor. But given that I'm facing the cost of replacement anyway, the extra expense may well be worth it. If the scientific data on PBO is correct then the longevity of the stuff will outlast steel bringing the net cost per year down to a reasonable number. It falls into the category of 'do I need a new genny now or next year?'..choices, choices...
