Hi All,I thought I sould let you all know that I discovered, the expensive way, that you should never use PB Blaster near ANY engine or transmission seals.I needed to remove my shaft coupling so I sprayed the four bolts with PB Blaster, thinking nothing of it, and let is sit over night. Evidently some of it dripped onto my transmission output seal and when I went to the boat he next day the majority of my transmission fluid was in the pan and not the transmission.My transmission is a 2003 ZF v-drive and had never, ever leaked a drop. After speaking with a few mechanics about this they know the problem well. PB Blaster can eat engine seals, transmission seals and plastic cups! Keep this stuff far away from any output shafts, engine seals or seals you don't wan't leaking.PB Blaster is great stuff but very dangerous to the tune of $800.00 on my transmission. Use it with caution!
