P42 genset alternative
I have a 5 HP Kubota diesel generator in my P42. It is connected to a scuba compressor and a 130 amp DC generator, of which I can only use one at a time, and I alternate by using electric clutches. It doesn't put out nearly the power of the larger gensets, so it won't power a heater or air conditioner. However, we lived onboard with it for several years (in areas where heaters/air conditioners were not required), and found that 1 to 1.5 hours of running time daily gave us enough power for our freezer, watermaker, and our other electrical needs, as well as providing hot water. The entire unit, including the custom frame for the compressor and generator, cost of the compressor, etc, was about 9K. If I had it to do again, I'd get a 6 HP Kubota and a larger generator. (The generator only puts out about 80 to 90 amps when the ambient temperature is hot and it has been running for more than 20 minutes).
