Has anyone removed the heat exchanger from a 4jh2 in a Passage 450/456? It appears that my aft end cap has corroded to the point that the exchanger will require replacement or welding. I have cut an access hatch in the shower/tub but I am concerned about the bolt clearances up against the bulkhead. Does the engine need to be shifted off of its mounts for access?
