Passage 42 water tank
1
Hunter P42 St. Augustine
My 1990 Passage 42 port side water tank seems to be leaking.
I have had the dubious pleasure of replacing the aluminum holding tank and this tanks seems to be substantially more difficult to access/replace. It looks like the hot water heater would have to be removed, the port bench disassembled and my fridge and freezer compressors removed.
If anyone has had to replace this tank I would greatly appreciate advice or comments regarding this tank replacement.
Cheers,
Jim
timvg
May 10, 2004
276
Hunter 40.5 Long Beach, CA
Your boat is most likely set up differently than ours, but I thought my 40.5 port water tank was leaking (because of the water I kept finding under the floor boards). Turns out, it was a small leak in the bottom of my 10 year old hot water tank, and the water just happened to drain back to the port tank area.
eianm
Jul 7, 2010
522
Hunter 42 Sydney
I have just done this on my P42 in December. Not such a bad job, but some tips;
1) to access tank (if you have not already done so) remove the sole ( floor) section in front of the 2 seater settee. 2) After all screws are removed slide it out on the RHS first- you need to do a bit of a twist to avoid jambing on the cabinet for the sink cupboard. Once floor panel is clear of this cabinet then simply pull back and it stand up- I left my floor section standing in the doorway to the front cabin, leaning against the door.
3) You now have access to your tank- centre hull cavity. Mine was installed with that horrible expanding foam- that was a bitch! I found an ordinary wood hand saw worked fine to break the seal between tank and foam and hull and foam. I then cut small sections of foam out progresively using a hand held hacksaw blade until it was pretty much all out. Before you can remove the tank you should empty every last drop out- I used a wet dry vac- unpleasant job, but at least I avoided more unpleasant spills when moving out the tank. The breather hose in the rear is a bit tight to get to , but you must remove this before you can remove the tank.
I used a Ronco Plastic tank- off the shelf and a great product, from very helpful people and cheap! See my post on big boat forum head P42 electric head upgrade for more details.
