Passage 42 salon/kitchen hatch gaskets replacement
juznip
Aug 4, 2022
18
Hunter 42 Nanaimo
What have you done to solve your situation?
Right now a tarp. I see there is a product on the hunter part forum that looks like it will work. Its a unique profile of gasket. D shaped but cant be sticky on the top…just occurred to me that maybe acetone could remove the adhesive and I could be good to go? Limited supplies in the local chandleries.
Jan 4, 2006
7,469
Right now a tarp.
That's always guaranteed to work :facepalm:.
I take it you've got a vendetta against Lewmar and Bowmar ?
C'mon, put some excitement in your life and get out there and take a look around.
If yours is a Bowmar, do some more searching.
PS. You also need the make, model, and year of your hatch. Without it :
I have both Lewmar and Bomar hatches on my H-310.
Trying to source replacement gasket for the 2 small hatches in the salon/kitchen. Anyone have a source? My internet searching has not turned up a match. D shaped but the flat part presses against the lens….
A little more information would be helpful. What hatches are you referring to in the Galley? Can you provide a photo of the whole hatch?
Dec 25, 2000
5,969
We have the same model boat and the two hatches in question should accept the gasket material referenced in my link above. Pretty standard hatch self adhesive gasket material. Used it before on some of ours. It becomes 'D' shaped after being compressed by the closed lens after a period of time.
