Passage 42 LNG to Propane Conversion
28
Catalina 34 Ladysmith
A member sent e-mail regarding our P42 conversion to Propane...well I lost it!!! Please send again and I can explain what we believe was a very successful project. Regards, Geoff and Vicki, SV "Flying Colours"
eianm
Jul 7, 2010
523
Hunter 42 Sydney
I will be intersted in this also- i am having SO MUCH trouble trying to get CNG- its impossible!
May 24, 2012
64
Hunter 42 Florida
Dreamtime. That would have been me I think since I did send an email.
I sent another email. I do want to know as I am taking on that project next month in preparation of splashing in July for a couple of years cruise! Maybe you could post here for others who will have the same question on what works and how.
764
Hunter 376 Pensacola, FL
Just throwing this out there for consideration - rather than going through the trouble of converting to propane, have you thought about just replacing your existing stove with one that burns diesel? Wallas makes several:
http://www.wallas.fi/default.asp?id=boat-stove-en
The advantages are that you don't have to carry a second fuel (propane) onboard, and apparantly the stove can also be used as a cabin heater with the addition of a blower assembly Wallas sells. The disadvantage is that they aren't cheap. But it's a boat afterall.
Two steps: you need to make a locker that drains overboard (the West Marine Advisor online and in the catalogs has a very good description of the requirements), or go external rail mount - many use starboard for "holders", and you need to change your burners, perhaps the oven, too - I forget. Call Dennis at Seaward in California and he knows exactly what to do - be prepared with the serial number of your stove from inside the opening top cover.
Lyle
Jun 26, 2004
114
Hunter Passage 42 Pt Roberts, WA
Any P42 owners that have done the conversion - could you please post pictures as well as how you did it? CNG just became a lot harder to get in the Vancouver areas with the main marine supplier closing its doors.
May 24, 2012
64
Hunter 42 Florida
I will post pics when I complete the conversion next month. Currently debating between the starboard locker or a deck mounted locker by the stern raill...
Lyle
Jun 26, 2004
114
No you are correct, CNG is available at filling stations - its the bottle exchange program that is impossible to find. I guess I should look at making the adapter. Not sure if the local filling stations allow filling of portable tanks - have to check.
Dec 2, 1999
15,184
We quit exchanging bottles a couple of years ago. We now spend about $2 to fill each bottle. We were paying between $25-30 for a fill. We normally fill the 4 bottles once each year and save about $100/yr.
