Parts for Boston Harpoon
Mar 23, 2023
1
Boston Whaler Boston Whaler NJ
Hi, I’m trying to fix a Harpoon 5.2 sailboat. I need a spreader. One is broken, but I guess I should replace both. Is there a place, in NJ, or an online location, which sells parts?
who made your mast? Are the spreaders swept back or athwart?
Try Rigrite.com they may be difficult to deal with, however they are often the only game in town. If the spreaders are simply Aluminum tubes you may be able to make your own. Check out a metal supplier, like Alro.com or McMaster.
The spreaders have a high compression load, so the tubing needs to be pretty strong. They must also be the same length so the rig's geometry is not changed.
