I'm having trouble figuring out how this charge circuit works. No charge from the main engine alternator unless the circuit breaker is engaged. When running the generator with the circuit breaker engaged, it seems like the starting bank and house bank are charging from the generator alternator and not the Freedom charger. When the circuit breaker is tripped, the different banks are charging at different voltages. There is a red light on the circuit breaker that is sometimes illuminated and sometimes not. Should this circuit breaker be set at all times or not?
