		John North
My wife used the head one time. I tried to use it now it won't dry bowl or wet bowl. It won't do anything.I found a lot of water in the bowl after the hurricane had agitated the boat for a couple of days and had to sponge out.If I loosen the screws below the pump, water leaks from the seal. Is there an intake seacock to close before replacing seals or valves.
