Painting
Oday 23 Winnisquam lake
Hi all. ABout ready to paint my O23. I know rolling should be done one way (up and down or side to side), and tipping the oppiste way. Which is which. Any other advise would be greatly appreciated!
Rob Hessenius
Chris- I just finished painting my hull last week. Here are a few tips that Ill pass on to you 1. Have another person do the roll out 2. Use 3'-4' Jen brand foam brushes 3. Use West System 7' foam rollers 4. Do a test coat on the transom for the proper thinning requirements 5. Have a set of tweezers handy 6. Wipe down the boat with 202 7. Always be thinking ahead 8. Be prepared to see your imperfections with the hull afterwards. If there bad, let it dry and sand out the issues. Sand out the hull with 320 between coats. Any questions, give me a call 920.203.1876. Rob Hessenius
Joe
Jun 1, 2004
8,342
roll vertical--tip horizontal
...and keep a wet edge.
Thanks...
Thanks for the input. Will probably have more questions as next Sunday (paint day) aproaches. I supposed it is like any painting project and I should start high, and work my way down, meaning do the hull first, let dry, do the water line next, let dry and then do the bottom paint.
