more info
I paint my boat once every two seasons using regular gloss white paint. THis time it will be Rustoleum, becuase that is what I have. It last the same, looks the same, goes onthe same as Easypoxy, a one part boat paint. How large is your boat? Mine is 37'. A small boat, 30' or so, would be about most peoples limit for what I do to mine. So if yoiu don't plan on doing it again soon, use two part epoxy paint.Next, how old is your tub? Mine is a 1976. Old. Not worth the money for two part. But I might get lazy two years from now.Whatcha got on it now? If it's gel coat and no paint, use two part, for a ten year lasting paint. If you put on regular paint, it might peel off or orange peel if you try to use tow part later on. SO, size of boat, age of boat, and surface conditions determine type of paint.
