Painting the bottom
Pat Corbett
I bought an R19 knockoff 2 yrs ago, mid-summer. It is old, with a thick glass hull, and no apparent problems. It was a lake boat, so the bottom had never been painted. The rest of that summer, it lay moored in Lewis Bay, picking up the usual detritus. I hauled out in the fall, scraped, etc, and painted the bottom with Pettit anti-fouling ablative. It then sat on the trailer until last Memorial Day.All last summer it lay moored, and the occasional scrub would remove any slime. Only a few barnacles attached. When scrubbing, some paint would come off in the water (slight "blue" tinge) but not down to the glass. I hauled last fall, scraped, scrubbed and got it nice and clean, where it sat on the trailer until now. My Questions: 1) should you launch soon after painting? If so, how soon?( I was told I shouldn't have painted in the fall and waited until spring to wet the hull); 2)Should some paint come off when scrubbing off slime during the summer? Any assistance is appreciated.
John K Kudera
Paints differ,
You should read the can, it should advise if what you did was correct, some ablative paints are multi season, others are not, and willnot be effective after sitting in the weather that long! Best of luck.
L
LaDonna Bubak - CatalinaOwners.com
Scrubbing
Paint sloughs off and if you're scrubbing, more will be visible while you're doing it. Nothing to worry about unless it's flaking off in big chunks. Some paints don't like to be dried out. You'll have to check the manufacturer recommendations on that. BTW, you can apply paint and launch immediately - it cures underwater. LaDonna
E
Ed Schenck
Paint, wait, launch.
Modified epoxies(I use Trinidad SR) are recommended to be in the water within a few weeks. Ablatives can sit all winter on the hard. But knowing that I still went into the water last Spring withOUT painting after sitting on the cradle for five months. When she came out the bottom was as clean as a whistle(Lake Erie). Be careful with curing in the water. I paint my cradle areas just a few hours before they splash her and those areas look very rough when the boat comes out. But modified expoxies are slow drying, maybe that's the difference.
