Chuck, nice boat!
Chuck:Nice boat, we have a '85 H'31.We are in the process of doing some research on this exact issue on my friends H'30. I am not a proponent of Paint. Unless you go to some of the more expensive 2 part Poly paints you may need to use different things to clean the decks.We have recently found a site that has a method for re-gelcoating your deck. It can be found at www.fiberglass101.com . Looks just as easy as painting and it is permanent. I think that IF you want to paint the non-skid, I would only consider a 2 part polyeurthane. This entire issue has to do with how much you use your boat. If you use it a lot, I'd think that you would want to do something rather permanent. If you don't use it too much then an enamel paint would be OK. There have been several posts on this issue this year. Check out the archives.The only other thing to think of. You may like a contrasting deck color, but if and when you go to sell your boat will the next guy like it just as much?
