several options I know of
Paul,I'm curious about this myself but I believe the options limit us a bit for practicality. I believe the options are:Paint the mast, lot's of prep and correct primer. Risk is paint will chip eventuallyAnodize the mast, probably not cost effective sandblast the mast slightly but it will roughen it up and you might not like the finish. Perhaps some other media like glass beads or walnut shells would leave it more polished. Ask a sandblaster, this might be the cheapest way to go.Clean the mast with an aluminum cleaner, they make a semi-trailer cleaner available at truck stops. You could also use Aluminum Jelly. These treatments at best would make the mast bare aluminum again and hopefully make it a uniform finish.In your searches let us know what you find available. Just some ideas that blew through my head.Steve P.
