We purchased a forty-year 24 foot sailboat and are in the process of restoring it.
My son and I have painted the sides and topsides of our sailboat with 100 percent Acrylic Exterior House paint. The improvements in Exterior Latex House paint over the years has resulted in a highly durable finish that can stand up to both sunlight and water. We are confident the Acrylic paint will hold up on the top and sides. The previous owner had applied house paint to the top side nine years ago and it was in fairly good shape except for a few areas where he had not properly cleaned the surface area prior to applying the new paint.
We sanded the top and sides, and then applied a primer, also 100% Acrylic. The following day, we applied two coats of 100% Acrylic exterior house paint. The paint flowed easily and went on without a hitch. We used anti-slid porch paint, also 100 percent Acrylic, on the walk ways on the top side. It has a tan color. Before and after photos attached.
Our biggest challenge appears to be painting the bottom:
We plan to use CM-15 epoxy for the barrier coats. We expect to apply at least two barrier coats and maybe three over the existing barrier coat that was applied nine years ago. The anti-fouling paint was removed, and we are down to the existing barrier coat. We do not want to use anti-fouling paint for our application.
What we are debating is what to use for top coating the CM-15 epoxy. This boat will be stored on a modified lift and will be out of the water whenever we are not sailing. My son has used tractor-grade enamel on a flat bottom metal boat and it has held up very well for that application, but that paint requires a respirator to apply.
After running my own tests on 100 percent Acrylic paints, I am seriously considering top coating the barrier coat with Acrylic paint, because it is so easy to use and less than forty dollars per gallon.
Samples, that I left submerged in water for weeks, showed no loosing or peeling of paint whatsoever. It was as if the paint had never been under water. The paint I applied to the top and sides uses nano-technology to bind the molecules during the drying process. The dried coating is water tight and keeps water from penetrating the layers of paint. It appears, unless the paint is scratched, water cannot get to the wood or fiberglass surface at all.
If I were going to use this boat on the ocean for long periods of time, I would not consider Acrylic paint for the bottom, but since this boat will live in fresh water and be on a lift a good part of the time, it sure would be easier to do touch ups or repaint if necessary with the Acrylic paint. You can scratch the Acrylic paint, if you apply pressure using the edge of a rock, but a fingernail won't phase it.
Has anyone tried using 100 percent Acrylic paint for bottom paint on a sailboat? If so, what were your results? My son wants me to get additional opinions before we go that route.
