Needs a coating of some kind
You aluminum mast need SOME kind of coating to protect it from corrosion. This is usually what is known as a conversion coating, a protective oxide, like anodizing, or paint. You can do either one yourself. 3M makes quart sized units of both the etchant and the conversion coating solution. Painting aluminum, many will conversion coat before priming. As stated in a previous reply, the first primer is usually a "wash primer," which is thin and not opaque. Yu can then epoxy prime, and then paint, ideally epoxy also.
