G
Glenn Bollin
After chipping off the loose paint on my 1988 Hunter 26.5, I discovered a lead keel. How do you prepare the lead beyound scuff sanding, primer? Also, what kind of paint should I use? Where the keel transitions to the hull the loose paint was up to 1/16 " thick. Should I smooth this area with some sort of filler? Maybe I should just bottom paint, throw her in the water and go fishing. Any advice?
