Over a half dozen people and sources have universially agreed that you can not put VC-17M over any other paint except itself because it has such aggressive solvents in that the older paint will lift.
When I decided to bring my bottom paint all the way up to the top of the boot top last year to avoid stern "fringe" from weight that has accumulated in the stern (windvane, etc.), I used Pettit copper paint for the boot top. I would like to use VC-17M all the way up.
The VC-17M almost flash dries so it is hard to see how the solvents are going to have much effect on the Pettit. There also has not been any sign of the inevitible slight overlaps at the junction lifting the Pettit. I plan to try a small test patch of the VC-17M without the copper. I'm pretty sure it won't cause a problem.
My question is: Is it possible for the solvents in a paint that dries within just minutes to work their way down without causing apparent loosening of the underlying paint but break its bonds in such a way that I'll find paint falling off in dual layer patches days or weeks later after the boat is in the water?
