Dave Winiker
I just installed a PYI packless shaft seal in our '87 Hunter31. Other than a little initial difficulty in backing the prop shaft out of the transmission coupling the entire process was a piece of cake. Now back in the water and all seems AOK except for a pronounced shaft vibration at about 1500 RPM which wasn't there previously, except for the usual Yanmar vibration at about the same RPM. I've checked for loose fittings, gear adrift etc. and have been unable to pin down the source. There was very little play in the shaft and the cutlass bearing seemed to be in good condition. I suppose I could simply ignore the vibration and accompanying noise and run the engine at a lower/higher rpm, but I don't want to really screw something up. Has anyone had a similar experience?
