Packing Gland Question / 1980 Hunter 33
Apr 3, 2023
8
Hunter 33 Brick
I have a 1980 Hunter 33 with 1 inch shaft. I installed 1/4 inch packing in the packing gland it was very difficult to insert and once inserted very tight. Also I was only able to get two pieces installed. Should I be using the 3/16 Packing.
Thanks in advance for your advice.
Yes. Watch the water drip. If you got all of the old packing out it is recommended that your put 3 pieces in. The smaller size and 3 circles will provide a better seal. Be sure to follow the instructions.
Cut 3 rings the diameter of the shaft.​
Make the cut on a 45º angle​
The length of the piece should be so there is a little pressure holding the cuts together.​
stagger the cut lines so they are not on top of each other at about 120º apart​
Close the stuffing box beyond snug tighten when in the water so water stops when no shaft rotation but drips when rotating.​
To keep the shaft and stuffing box just warm to the touch.​
MaineSail has a great article on the stuffing box. Can be found here. Re-Packing A Traditional Stuffing Box - Marine How To
This thought describes what you are trying to achieve.
"If a stuffing box is allowed to drip, even at a slow rate, it allows for excellent cooling, longer shaft life, less opportunity for crevice corrosion and less opportunity for trapped air to run the box in a totally dry state and cook it. (MaineSail)"
Apr 3, 2023
8
Hunter 33 Brick
THANK YOU
