When I bought my boat about three months ago (a 1986 Hunter 34), it was noted in the survey that the engine shaft packing gland was dripping excessively (about one or two drips every second). I brought it to the attention of a mechanic who tightened this. About two weeks later, while motoring, I suddenly noticed excessive vibration nosie (more obvious at certain RPM's than others). The packing gland is again dripping as it originally did. Would this be an issue with the cut less bearing? Did he possibly over-tighten the packing gland, causing excessive friction and heat? What is my next step? Am I able to use my boat in the meantime or does this require an immediate fix?
