Ben Duggar
We have a 1995 Passage 42 which we cruise in tropical waters as liveaboards. The forward water tank is aluminum and I can get to it to see that there is no inspection port. One can get to the valve connecting this tank to the water line and use it to drain the tank. The main tank, however, is below the salon floor under the table. Even if I could get to the tank I would not be able to use gravity to drain it. I have found a precipitate in both tanks and it is occasionally blocking the lines to the fresh water pump. Has anyone else encountered this problem? If so, how did you get into the main tank to clean it? Any thoughts as to what the precipitate is and how to prevent it?
