P42 water tank valves
G
Guest
Hi Ted, the two tank valves, one for the forward tank and one for the aft, are located next to the hot water tank beneath the port seat. Remove the seat cushion and remove the hatch and you will see the water pump, pump strainers and the two valves. They each control water flow from the tanks. I think the outboard side valve controls the aft tank, which is beneath the sole board.
Terry Cox
