P36-2 Transducer location
NYSail
Jan 6, 2006
3,145
Beneteau 423 Mt. Sinai, NY
Once again.... My speed and depth transducers are located under the long floor board opposite the table. This board is screwed in with access to this area only by removing the screws.... In the front cabine, there is a floor board with a hole in it for easy access to the hull. This appears to be right infront of the keel. In the case of an emergency if a transducer where to break I would loose a bunch of time unscrewing and was wondering if the p/o installed these in the wrong place. It would seem logical to have easy access to check them periodically. Also I know having the speed next to the keel distorts the reading due to the speed of the water running over the keel. Thanks again Greg P36-2
A
Ariel
Transducer location
The transducers should be ahead of the keel. The removable floor in the forward cabin is for access to the transducers.
NYSail
Jan 6, 2006
3,145
Just what I thought
Thanks! Great photo ....now another project for next year! Greg P36-2
