E
Ernie Rodriguez
Is anyone aware of any data that compares frictionl losses of the P.S.S. system with the frictional losses of the conventional stuffing box/flax packing? I have read some of the past forums on the P.S.S. but most deal with the dripless feature. Although this is a good feature, I would consider using this system if it has other benefits besides just the dripless, no leak performance that everyone craves about. I have used the Syntef Drip-Less packing system which also results in less water coming into the boat, but I have no idea of what the frictional losses are of either system. The Syntef system indicates that it should not be used in systems where the shaft speed results in a 900 FPM speed. (FPM not RPM) The 3GM engine with the 2.61 transmission reduction gear would result in a shaft FPM of 300 at an engine speed of 3000 rpm, which is 3 times below the recommended upper limit. Is there an upper shaft speed limit specification for the P.S.S. system?I am still looking for sources for additional loading on my 3GMD engine at the higher rpms and have not seen any reference to power losses from the shaft seal vs rpm. Would appreciate any comments/suggestions on this.Thanks,ErnieH-36
