OZecoDrive
Mar 6, 2012
53
Hi All,
NOTE: I realize this was discussed several months ago.
I am about to repower and can't get the idea of electric out of my brain. I
have looked at several systems on the various websites and think the one
made in Sweden by Ozeco would work well in a Vega. I fully realize the
limitations in range under power, etc, and the weight issues with the
batteries, etc.
If I read the Ozeco website correctly Vega 1150, located in Karlskrona had
one installed in 2002. The owner is Ingvar Hansson. I would sure like to
communicate with Mr. Hansson about the installation and how the drive is
working out after a few years.
Or if anyone has any additional information they would like to share, that
would help too.
Thanks,
Chris
Vega 2923
[Non-text portions of this message have been removed]
Jul 26, 2004
90
Chris,
We have been fascinated with the electric option for our Vega, as well, and have gone so
far as to get a quote from OZeco. I will copy and paste it below. I assume it would be
pretty much the same for any Vega.
I would say that if there were several of us who decided to take the plunge, they might be
willing to offer a little better deal. Also, we could all work on the installation in concert.
Anyway, it\'s something to think about. Hope this helps a little.
Jody and Rick
\'Snipp\'
OFFER OZecoDrive Electric drive system
Name: Rick Schroath Boat: Albin Vega
Offer nr: 827
Offer handled by Oscar Mattsson
EXTENT OF DELIVERY
1. OZsingle motor, 4 KW, D 225×140mm (55 RPM/Volt)
2. OZ motor mounting complete
3. OZ axle coupling
4. Propeller axle, D 25mm.
5. OZfoldProp (14"×8"RH). Two-bladed folding propeller.
6. OZ sacrificial node.
7. OZ demounting tool for the propeller.
8. OZ axle sealant complete.
9. OZ axle pipe in stainless steel with cornet.
10. OZ low friction axle bearing, D 38/25 X 40 mm
11. OZquickShift, lever and regulator.
12. OZecoCharge, propeller charging electronics.
13. Combined motor fuse and automatic breaker unit.
14. Customized cabling, 6 x 50 mm2.
15. Mastervolt switched battery charger 12 V/25 A.
16. Battery temperature sensor to the charger.
17. Customized cabling to the charger, 2 x 16 mm2.
18. Mastervolt BTM-1 Electric tank meter with. "Time To Go", V, A, %, Ah etc.
Total weight (1-18) = 44 kg.
PRICE
Posts that are Strikethrough are excluded. The price is without taxes, batteries and freight.
The price (may vary with the exchange rate) for the component according to the extent of
delivery is;
PRICE 4762 USD (39858 SEK 11/22/05).
GUARANTEE
A guarantee valid for 3 years covering malfunction erratic material is given on the
products above.
BATTERIES
Eloch fiber battery: Capacity: 12 V/110Ah
Measurement: 175×330×225
Weight: 32 kg
BATTERY BANK AND PERFORMANCE
With four of the batteries specified and with OZ parts according to the extent of delivery
your boat is expected to get the following performance;
Economy speed: Above 3 knots for 8½ hours. Maximum speed: 5½ knots in 50 minutes.
Note that the maximum speed is limited to save energy but the thrust will increase if
needed.
Oct 31, 2019
303
Jody and Rick,
I am glad someone else thinks as I do. I would love to discuss this further.
Where are you located? I am just north of Seattle, WA.
I have discussed this with the fellow at Ozeco too. I also have quite a bit
of information about batteries, etc as my son-in-law used to manage a
battery warehouse. He is also a ABYC certified marine electrician, and he
even volunteer to help install. There is a battery brand that looks better
than others Northstar is the name, but they are a little pricey.
NorthStar <NorthStar> is the
link, then go to HD Marine.
If you want to contact me independent of the general group (to save those
not interested in getting too much email on this subject) my email is:
SVFlyaway@....
Chris
_____
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf
Of schroath
Sent: Wednesday, February 01, 2006 10:03 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Re: OZecoDrive
Chris,
have gone so
it would be
they might be
Jody and Rick
\'Snipp\'
Offer nr: 827
EXTENT OF DELIVERY
3. OZ axle coupling
Ah etc.
PRICE
the extent of
delivery is;
GUARANTEE
on the
products above.
BATTERIES
Weight: 32 kg
extent of delivery
minutes.
increase if
needed.
